Yamaha Owners Club: DT50mx bits required - Yamaha Owners Club
Page 1 of 1
  • You cannot start a new topic
  • You cannot reply to this topic
#1 User is offline   Dufferz
  • Member
  • Group: Members
  • Gender:Male
  • Interests:Motorbiking, Computers, Friends
  • Bikes:Yamaha DT50MX '84
Post icon  Posted 14 March 2009 - 10:11 AM
Wanted for DT50MX:lol:
-piston and barrel kit(60cc) I think I know somewhere I can get one of these, but I'll post here anyway
-crank( :angry: )
-oil pump
-gasket set (full)
-all bearings
Posted on my iPod, will re structure when on real pc
#2 User is offline   ally tonks
  • Member
  • Group: Members
  • Gender:Male
  • Bikes:v75a 1977
Posted 14 March 2009 - 01:15 PM
-crank( :angry: )
-oil pump
-gasket set (full)
-all bearings
Hey Duffer
Do you know the model code for this bike?
Ally :)
#3 User is offline   mervin
  • Member
  • View gallery
  • Group: Moderator
  • Gender:Male
  • Bikes:RD250 D RD400D RD400 E 1991 TDR250,1988 TDR 250
Posted 14 March 2009 - 06:41 PM
does that have the minarreli engine?
merv
Posted Image
#4 User is offline   wild foamy
  • Im not a complete idiot, some parts are missing
  • Group: Members
  • Gender:Male
  • Interests:Aviation, Fishkeeping, Motorbikes, Engineering, Homebrewing, Music, Guitars and obviously Girlies ;)
  • Bikes:1990 Yamaha DT50 MX,
    1994 Jawa 350 Blue Style (ongoing project)
Posted 14 March 2009 - 06:47 PM
What year is it mate?
your going to have to split the cases to change the crank and bearings so make sure you have a haynes manual.
most, if not all of those parts are available from eBay, best seller is called "Yambits" and i have often bought my DT parts from him and enver had a rpbolem, postage can be combined on multiple purchases aswell.
just out of interest, how did you manage to do so much damage? :o
ive got a DTMX aswell, so let me know if you need any more help
Press Alt+F4 for a good time!
#5 User is offline   Dufferz
  • Member
  • Group: Members
  • Gender:Male
Posted 14 March 2009 - 10:48 PM
its a 1983 model.
I know i need to split it all down foamy ;) i've been looking at your DT for sale, its very cheap :)
I dont know how so much damage happened, i'll try and get some pictures :( the piston's bottom half is completely shattered, there's 2-3mm free play on the con-rod; and the teeth on the outside of the clutch basket are half ground-away.
Inside the top half of my piston it looks like its got 2 of the bearing spacers in the top of it (metal pin things?) completely nackered =[. The small end is completly nackered (looks like a mouse has been biting the piston)
Just having trouble getting the clutch basket itself off, lost the holding thing
#6 User is offline   wild foamy
  • Group: Members
  • Gender:Male
Posted 14 March 2009 - 11:52 PM
im afraid my DT is going to be staying for a while, im only going to be keeping it for 7 more months so theres no point getting a new one really, it does the job :)
Its taking me around Republic of Ireland in a couple of months aswell, should test its reliability a bit :P
if the small end is knackered, chances are its worn away the conrod aswell so you will need to replace that if it has, its probably going to be cheaper to buy a second hand DT engine off ebay
if you weren't so far away i'd have been happy to come give you a hand with it!, i probably know my way around my DT better than the blokes what made it!, lol
good way i found to hold the clutch was to put it in 5th gear and put a brick in front of the back wheel
#7 User is offline   ally tonks
  • Member
  • Group: Members
  • Gender:Male
  • Bikes:v75a 1977
Posted 16 March 2009 - 12:36 PM
-crank( :angry: )
-oil pump
-gasket set (full)
-all bearings
evilbay 120392514965 for big bore kit......
#8 User is offline   wild foamy
  • Group: Members
  • Gender:Male
Posted 18 March 2009 - 05:48 PM
thought his may be of interest to you m8
http://cgi.ebay.co.u...A1%7C240%3A1318
best ask him how much use it has had (mileage) but it looks okay for the price.
if worst comes to worst and that engine is junk, you can scavenge the oil pump, carb and crankshaft and dump the rest
#9 User is offline   Dufferz
  • Member
  • Group: Members
  • Gender:Male
Posted 25 March 2009 - 10:39 AM
Hi Foamy, just ordered everything I need from site called WeMoto, good service there and fast delivery too. Ordered bigbore kit, con rod kit, thrust washers, gasket set and lh&rh main bearings. Should be here tomorrow or Friday. Managed to lock the clutch by welding a steel rod onto the steel clutch plate. Worked wonders :) might keep that in mind for future projects.
Turns out the pin things were the rollers from the small end. As per my original theory. One of my friends dads has access to a crank thingy aswell so thats sorted
#10 User is offline   wild foamy
  • Group: Members
  • Gender:Male
Posted 30 March 2009 - 03:24 PM
good to hear theres going to be another little blue dragon on the road shortly :)
any pics?
#11 User is offline   Billy47
  • Member
  • Group: Members
  • Bikes:Yamaha DT 50
Posted 18 November 2009 - 09:54 PM
yeah i have a dt mx and im the 10th owner, wehn i bought it it came with all the spares its ever had and that included several piston and barrell kits, aparently these can crack over time so that is not a worry and it gets worse as you use a bore kit, ive been through one piston already as i have an 80cc bore kit.
Page 1 of 1
